What's up yall,
The guys over at the HAMB suggested I post here, so I joined up as a new member.
I was trying to get rid of some electrical issues on my '63 Fastback when a terminal on one of my firewall harnesses (8 connector, 6-male, 2-female, engine side) broke.
It's the 2nd harness from top at the firewall below my brake booster. Pic is attached of the broken part.
Anyone have a replacement that they might be willing to part with, or where to get one (perhaps a universal or from Dearborn, etc.)?
Willis
Towson, MD
It might be the one - I'd have to check what else the wiring connects to. I hope I don't have to spend 100+ dollars for just the firewall connector...
Still looking for anyone that might have the terminal to sell...I'll call Dearborn tomorrow to see what's up.
The Easiest route for that if you're not trying to win any concourse shows is to simply cut the corner of that plug off, and install a single wire pigtail for that terminal. Easy, aesthetically normal and not time consuming.
Simply put a nice male tip on the end of that wire, remove the corner of the plug, plug in the plug and separately plug in the last male wire. Easy schmeasy.
FE
Another option is to dig the connector out of the plug and put a new one in its place. It is just an uninsulated bullet connector in a big rubber shell. It is the bigger size that can be a little harder to find. The 1.56 is the smaller size that is easy to find. Older Fords use something like a 1.80 size.
Discussion Starter #7
I tried to remove the connector that broke and ended up having to cut it out entirely. Got a single bullet connector and soldered it to connect to the previous wire. Problem is now the entire harness doesn't want to seat (I don't think the new single-bullet is in the way; it just doesn't want to seat all the way). I may post a request in parts-wanted to see if someone might have one. For now I'm afraid the harness will vibrate loose on the road...
Discussion Starter #8
I took some clearer photos of my attempted fix, but I'm still not confident that it'll hold up under road travel/vibration.
Any idea on what Part #'s these harnesses (male and female) may be? I have a scanned Parts catalog but there's no way to tell which part #s they are:
I think your going to have a tough time finding the correct plugs. I would suggest you find (good luck) a donor harness. In your case you will probably need both harnesses, if the one inside the car is bad. You could try Greg Donahue, if nothing else he may have a few words of wisdom for you. My 63 has act up occasionally because of road vibration. It seems to me the last time I had issues I placed a small amount of dielectric grease on it, that was seven years ago. Not too many years ago I went to an old junk yard not to far from you just over the PA line. They had at least six Galaxies laying around.
