1 - 9 of 9 Posts
Replacing your late model healiner is really easy once you get the old one out. Here is what I did on a 1989 Ford Ranger XLT. I first took it out and laid it on a table/stand that's handy.
Just nice and slowly peel off that saggy hanging mess and toss it in the trash. Next you will need to remove all of the foam backing from the very delicate fiberglass backing. This looks harder than it is and repairs are simple, see below. That's right! Time consuming but it works excellent. Take a low to medium speed drill (electric or air) and a multi-wired semi soft wire brush, not the large heavy gauge wire wheel that's made for high speed wire wheeling.
Check it out! Sometimes it's a little harsh if you're not paying attention, but never mind those small bare patches, you'll never even see them once you're done.
Below you'll see a big ugly hole with a finger... Well just tape it up from the back like the following picture.
Tape is good.
Then you have to stabilize the fibers so that your new headliner has something to stick to. I used an entire can of Black Semi Flat Rust Tough Enamel paint by Krylon. It's good and strong and penetrated the fiberglass backing quite a way's in making an excellent new backing.
That black surface allowed to dry about 3 hours. I goofed up and didn't take pics of spraying the headliner adhesive but here's what you do:
1) Lay the new headliner (got mine on E-bay from auto krafters) and center it so you have the entire pad covered.
2) Peel back one half slightly farther than half way.
3) You can get the Headliner glue in a 15 ounce spray can from your local parts store. They come with 3 settings in the spray nozzle, light, medium and heavy, I used medium.
4) Spray the exposed backing, and the headliner and allow 4 or 5 minutes to dry, spray evenly and try not to miss any thing by crossing your pattern on the backing.
5) Once several minutes have passed, slowly and evenly lay down the headliner with the smooth even pressure from the PALM of your hand, from the Center out to the edges.
6) Then turn it around and repeat for the other half. Below are what your results will resemble.
The new headliner is basically ready to handle one to two minutes after gluing the two halves together. Trim up the excess and you're ready to go.
Badda Bing Badda Bang, You're Finished.
Hey! FE,
Greart tech article! It just so happens that I need to replace the headliner in my '92 Ranger. I already have the replacement kit. Yours looks to be an extended cab. So's mine. How difficult is it to get the headliner out of the truck? I know the trim has to come out. But how did you get that big piece out of the cab without damaging it? I thought about removing the seats to make room for removal. Any advice would be greatly appreciated.
Thanks!!! Have A Great Day!!! Keith
Actually Keith, your headliner will come out nicely by slightly bending it in the middle.
With the interior panels out:
On the rear panels with the seat belts going through them, just pull out a lot of seat belt then let the panel hang outside the doors directly inside-out of where they sit in the cab. :)
Slightly bend the headliner, and bring it out diagonally, with the forward edge down towards the feet area.
I was going to photo that part also but got sidetracked... :D
Pass seat all the way forward, driver seat all the way back, is what I did I think... It was 2 weeks ago...
Good luck!
FE
Thanks!!! FE. Yea I know about that memory thing and about being sidetracked :). Happens all the time :confused:. I have a hard time remembering yesterday.
Thanks again for your help :D.
I know this is is an old post, are the links broken or moved, they don't seem to be working???
Thanks, Joe
I'll go find the pictures and give them to Rick as soon as I can.
Thanks, looking forward to it, I need to do one in a Fairlane, not sure I want to tackle it or leave it to a pro.
Sometimes a guy has to choose his battles, but then again it is how you learn how to do new things, you just do them a few times...No offense meant to you upholstery guys, I know it is a talent.
Joe
1 - 9 of 9 Posts
