Hey guys, I have made great strides getting my 66 wired correctly. I'm down to getting the reverse lights setup. I'm not sure what's wrong, everything seems to be hooked up correctly. I see in my wiring diagram there is a reverse light switch, could this be the issue? If it is I can't find it. Also I checked the bulb to make sure it's good. I attached an image of my diagram.
It is combined with the neutral safety switch. Depending on the year or transmission, it could be on the steering column or transmission gear selector shaft.
Its on the column under the dash on a 66. They sometimes get misaligned, meaning the lights may only come on between R and neutral or R and P. I would check that first. With the key on, have someone stand behind the car and watch while you slowly change from hear to gear.
Also check your grounds.
