Here's the deal. Since the OEM column has been replaced and the harness signal switch is on the floor board. I have been rewiring the new rocker panel. The original headlight switch is still in the car, headlights hi-low, runs all work fine. Tapped into the turn switch and wired the rocker panel everything works RT & LT turn, in dash indicator lights.
The million dollar question: Where does the brake light wire tie in ?
I have tried multiple combo's and know I am missing something simple. A little expert advise please. TODD
