I know not to many people have six cylinders on here, but I doubt that will make much of a difference as to what is causing this problem.
Car is a 200 ci 6 cylinder Mustang with a C4. Split headers, weber carb, electronic igntion, soon to swap the head with a late model 250 with modified intake.
Ever since I've had the car, I've had a problem with a rhythmic vibration coming from underneath the car - somewhat on the passenger side. The vibration is much more noticeable when the car is cold, and is present only at low rpms when the car is moving. If I'm accelerating from a stop, the pull through first gear and second gear is strong and smooth, but when I'm at the point that I stop accelerate and just maintain speed (between 1500 and 2500 rpms, which equates to about 30-45 mph) the vibration starts and doesn't stop unless I speed up to about 50 mph. Above 50 mph and below 30 it's fine, but between there the vibration gets annoying. It's not gotten worse since I've had the car.
I've replaced the driveshaft and universal joints, and had 2 different rear ends. No difference, but when I switched to the 3.20 rear end from the 2.83 the vibration sped up in rhythm (probably to do with the faster ratio).
Any ideas?
Any ideas?
