I have a 66 galaxie with a 390. Replaced the frame but noticed the ride height is alittle high. I was thinking of cutting a coil from the front and adding compressors in rear. Anyone else do this?
Before you do that, loosen all the suspension nuts and bolts so the suspension can flex. Then take it for a few short bouncy drives. Then retighten everything with it setting on the ground. Sometimes the suspension gets tighten when in the air and this locks it into a higher stance,.
