Well I've been running a 4.10 31 spline Detroit in my 85 Bronco with a healthily built
351 W (4bbl, headers, edelbrock performer intake/carb, Crane RV cam, mildly ported, MSD ignition) and a C6 with stock converter turning 36" super swampers for about 6 years now. Last saturday, after making a turn there was a loud KAABANG from the rear end. I thought the driveshaft broke loose again. But I was still able to drive, I locked it in 4wheel and creaped home. When I yanked the diff out last night, I found 4 of the ring gear's bolts were sheared off, 5 or 6 were bent up to 90 degrees. the driver's side bearing cap on the third
member broke out at the center, the diff clamshelled open, the bearing on the driver's side disintigrated.
All in all, a real mess. When I installed everything 6 years ago, I followed all the torque specs and adjustment procedures. If I do this again those ring bolts are getting RED loctite'd.
Just wish I knew what the sequence of events was causing the failure.
Anyone got any ideas?
I don't see how they could've bent unless they came out. That's why I was looking for other people's input on this
Sure sounds like they backed out on you. The bolts are only an inch long or 1 1/4". You did use new bolts the first time? Most places and probably Ford too, doesn't reccomend re-using ring gear bolts, especially in performance or H/D applications.
Make sure you check the ring gear bolt holes for screwed up threads if you are going to re-use this gear set.
Also, check the locker for oblong holes too.
96 Ford F350 PSD CC DRW
97 Ford Taurus
64 Fairlaine 500 rust bucket/future Tbolt clone with 514 BBF
<font size=-1>[ This Message was edited by: Just Strokin on 4/18/02 12:29am ]</font>
Can't reuse it, the thing is bent to hell (the halves of the locker are bent open).
They were new bolts, bearings, gears, differential and outer axle bearings.
Just wondered if anyone else has had/heard of similar things happening.
