Can anyone tell me the installation procedure for installing the stock rocker arms on an '87 mustang engine (should be the same for at least '87-93 engines). I'm replacing my valve seals and I want to make sure I get my rocker arms back on correctly.
Thanks in advance,
-Eric
If you are just putting the stockers back on then make sure you put them back where they came from and any shims they might have had w/ them. They aren't adjustable without changing the pushrod length and shimming. So once they are set right you shouldn't need to do anything special.
Get them properly positioned and bolt them back down. Can't tell you what the torque figure is though.
