I am running the Ford OEM bodied roller lifters, that are modified by Sherman to only have 0.015" plunger travel, dog-bones and spyder with a custom MME hyd roller that has 0.640" lift on both sides. I believe my block is a late 71, but I'm not totally sure on that. Leave it up to Ford to change the lifter bore heights during the production run.On 2006-04-09 12:48, speedar wrote:
Would the difference perhaps depend on how much lift you each have?
In my digging for the truth on the retro-fit issue I came across a post that indicated the different base circle was also needed to ensure the lifter went low enough in its bore to pick up the oil feed.
