Hi
I have installed my roller cam with just assembly lube and just engine oil on the cam lobes.
For the Lifters, I have read I need to soak them in Oil overnight before fitting. Do I then use assembly lube on the roller itself?
The engine will be a long time in the build, Is there anything else I need to do?
Martin
Hi
Martin
It is advised that hydraulic lifters not be pumped up before the initial fire. If the engine is going to sit, they will bleed down. I would use assembly oil on the lobes, rollers and lifter bores if it is going to sit.
But the valve springs (compressed) may weaken sitting for a long period.
