Has anyone replaced the rubber insulator that goes on the end of the shift lever on an automatic column shift. I have a 63 Galaxie but don't know how to remove the shift lever. I'm afraid if I remove the roll pin I can't put it back. Otherwise it works fine just a little loose. It may not be worth the effort. Thanks.
I believe you have to remove the roll pin and then the shift level pulls right out. You have to use a small punch the same size as the pin. You shouldn't have any problems putting it back in, it just hammers back in.
