What is the easiest way to run with a vacuum modulator with an engine that runs boost. Is there a way around it or is a manual valvebody the best way. Would it even be possible to have auto shifts?
I believe there is a way using 2 one-way valves in the vacuum line ,but once boost came in and the signal to the modulator is lost would the trans hold on to gears?
