Ok, here is the engine
75 351 block bore 60 over
JE Pistons 11 to 1
Scat 3.85 stroker crank
Scat H-Beam rods
Main Cap Gridle
J302 ported heads (flow= 270 int. 206 ext. @ .600)
Comp solid roller cam (.600" lift 286deg int. & 292deg ext.)
Comp pro magnum rocker & comp lifters
Victor Jr intake with 750dp holley
MSD billet dis. w/blast2 coil & Digital 6 Box)
1-3/4" Hooker headers
NX twin stage 6 nitrous system (50-300hp in each stage)
Here is the problem.
I can not get it to lean out. I have check the power valve and every thing related to the carb. No vacumm leak. Timing is locked out at 32deg. New autolite AR3933 race plugs. New motorsport 9mm wires. I have also installed and O2 sensor which is telling me the engine is rich, the blue smoke coming from the exhuast also indicates a rich condition. The carb. jet are currently 66pri. and 74 sec.
Any help would be welcomed.
Thank James
1) Is it always running rich? If not, what circuits are rich, IDLE, POWER or WOT?
2) Have you tried re-jetting and what was the result?
Carburation is always the suspect, but not always the cause.
Paul
The factory carb jets are 70 pri and 80 sec.
I have adjusted the idle mixture to lean it out at idle (still a little rich). The four corner screws are adjust 1 turn open on the primarys and 3/4 turn on the secondarys. As soon as I get on the gas the blue smoke come and the O2 shoots to rich.
The carb has been worked over by carb shop. So I don't think it is the carb. I check the power valve with a vacumm pump. It's a 6.5 in valve and I am drawing 11 in of vaccum at idle.
What do you guys thing the timing should be?
James
