My sister's '94 6 cylinder T-bird was totalled, but the running gear is perfect. Her daughter has a '67 Mustang with stock everything(289/C4/8" peg leg, drums). Could the T-bird's discs be swapped into the Mustang? Are any other T-bird parts useful to the Mustang, for instance, the AOD? Thanks.
I couldn't tell you if the discs would fit, but the bolt pattern is wrong, if your Mustang is a 5 lug it uses the 5 - 4 1/2 pattern and the bird has a 5 - 4 1/4 pattern
as far as i know, the "mn-12" t-birds have a 5-4.5 bolt pattern on their wheels, i had a guy give me a set of aluminum wheels from a '93 and they bolted up to my '68 torino, the offset was wrong though.
