Scat and Eagle have cast and forged cranks that are equivalent. The forged ones are about $700 or $900-1000 for lightened ones.
Scat also has the 7000 series for $1000-1500. These can be custom ground for any combination of stroke and journal size. They are also available in a 'superlight' if you kept the bobweight around 1400gms or less.
Internal balance is better. On a 302 it was difficult with a heavy 1960's stock rotating assembly. Scat and Eagle are both offering it. However, most flywheel and damper offerings are designed for 28oz or 50oz balance. So, you need to make sure all the pieces match. And be careful about it the future wrong. Get it wrong, and you can find out about it in a very expensive way.
Callies, Crower, Byrant, and Kings all make high end cranks. US sourced materal. Some design characteristics may be a little better, especially with the Callies and Crower. More sophistication on where the weight is and the strength of the component. Callies also does an induction hardening, which is a deeper penetration. Around $1900-2100 for Kings. $2500-2700 for the others. In their lightest versions.
The cast cranks from Scat and Eagle, which are $250-300, are perfectly fine for most applications. My rule of thumb, over $5-7k engine, forged, over $12-16k engine, Crower or Callies.
IMHO,
