Do the scat cranks come machined for a one piece rear seal or a two piece?...I haven't seen any difference in part #s so I'm wondering ..I have a 1982 block which I assume has a two piece seal and I'm wondering if I can convert it to a one piece seal or if not is there additional machine work that is needed on the block or crank?
According to existing literature from Scat, you can use the crank in either type block with no modifications needed to the block.
Dennis
65' STANG, 3160 lbs
393W NA, 2.78 Toploader 4 Spd, 9" 3:70 Posi
Pro Comp Heads, Vic Jr. Intake, 750dp, 236/561 Solid Cam, 9.6CR, 1 3/4" Headers, Lakewood, Subframes, Caltracs
<font size=-1>[ This Message was edited by: dennis111 on 11/18/06 11:41pm ]</font>
