Hey guys I have a 66 straight 6 that I'm converting over to a 289. Well I have rf-c50p-7976-a lester 2 bellhousing that I found and everything lines up bolt wise. However the starter holes are off by about 3/4 of an inch on the seperator plate.
Anyone know where I can or how I can locate the right plate? Am I screwed and just need to start chopping?
Picture below
Is that the 6 cyl plate?
If so, you need the V8 small block plate.
Don't cut the plate!
It properly locates the starter with respect to the ring gear.
Get the correct plate.
Picture below
There should be a Ford number stamped on the plate, it won’t be an actual part number but can be converted to what it actually fit.
"..Well I have rf-c50p-7976-a lester 2 bellhousing that I found..."
what the heck is that?
Doesn't modern drivelines have a 'listing of different bells' chart on-line? Get the correct bell for the combo you will untimely use. Not doing so will complicate. Place the block plate U have (from the conversion) with the i6. Sell them together to fund the correct 289 bell (or whatever it is U will B swapping in). 200/3.3 and 250/4.2 i6 motors get 100 - 500$USA. One spot is ford6 in their '4Sale' forum...
I C no "Edit" function here but I can add this from an earlier post here:
