Serial #\'s location help needed
756 Views 3 Replies 3 Participants Last post by  ckelly
Hey, I have a 351C and was wanting to check and see if it is original to my car. Where are #'s located? The only thing I found was above the starter and they are cast in and not stamped on. That leads me to believe they are not the ones I am looking for. Also if the #'s I found are not what I need what are they for? Thanks
Try on the back of the block on a pad near the oil sending unit.
On top of the block at sending unit or between motor and tranny?
<font size=-1>[ This Message was edited by: dmoore0733 on 4/11/06 5:35pm ]</font>
Typically you won't find any. Look on any machines exposed surface, but don't think there's a problem if you don't find anything.
