does any one know of a service reset tool that is for a EEECV
Are you talking about resetting a service engine light?? You have an obd2 system which HAS NO CHEAP aftermarket tool to reset your engine light,if this is what you are talking about? OBD2 stores HARD codes which needs a scanner to RESET!!! It's not like it use to be ,just disconnect the battery for 10 seconds!!You need a scanner to reset a service light from 94 models on!!
