At the beginning of racing season I rebuilt a c4
For my dads car. This was a ******* c4 pretty basic
With a tci RMVB and tci servo in a c5 case. It appeared
that some
One had damaged it by letting the washer behind the
Pump fall and bolting it down and ran it anyway.
I am a good and meticulous mechanic so I went
Through it and replaced all the hard parts that were
Damaged and new frictions and set all clearences and
Endplay to spec. Having very limited internal trans experience
I was actually very confident that it was a good repair.
The problem comes in that the car didn't run nearly as
Quickly as it should and dad complained often that it felt
Like the trans was dragging. I had it open 2 more times
Checking everything for signs of an issue and everything seemed
In order. Now that the seasons over and the tea
s is out I pulled the servo to stick in my trans and I noticed
That the case is pluged and both o rings are on the piston.
I know enough now to know that is a no-no but no one has explained
What can happen when this is done so I know if this will cause
An issue like this or what else. Any info that someone can offer
Will we much appreciated as I would like to have this problem resolved
And have this trans perform as good as mine.
that some
