how do you set fuel pressure on a holley regulator?? Im using a holley blue fuel pump....i thought you jus ran the gas line in to a gas can and adjusted it what you need...but i did that and it wouldnt come up over 3psi.....but when its hooked to the carb and i adjust it, it wont go below 12???
you have to have it going to the carb, dumping into a can is not going to give you an accurate pressure reading. Not sure why it wont go below 12psi, what pump are you running?
Banned
You are turning it the right way to reduce pressure? Actually you need the engine running so the fuel will be used off. Otherwise the pressure will just set there. 7-7 1/2 psi is what you're looking. Pressure is resistance to flow. To get an accurate reading you have to have both flow and resistance.
