1 - 20 of 25 Posts
I recently installed a new comp cam and after running for under 100kms am tearing apart the bottom end, and when removing the crank I noticed a lot of shaving inside the cam eccentric that runs the fuel pump from the front cover
I guess the spacing isn't right, but the eccentric isn't new and was on with the old cam that didn't cause this problem
has anyone run into this before?
thanks, Jon
HI
You might have some cam walk going on... is the cam shimed in right? how much play is there in the cam (front to back). maybe pull the eccentric and see what the block looks like...
tim
That's too much. Should be in the .010 end play area. Never used shims on a Ford cam - the gear and the retainer set the clearance. Sounds like something's shewed up in that area.
Discussion Starter · #10 ·
well with the eccentric off i can grab the snout of the crank and move it 3/16 to 1/4" back and then pull it forward to the plate
i assume this isn't normal?
Discussion Starter · #14 ·
yea sorry i mean cam
and i think it is just a problem with too long of a dowel pin in the cam to locate the eccentric, the washer is bent pretty good, and the plate holds the cam in from going far and when the eccentric is bolted in the cam can't go anywhere.
<font size=-1>[ This Message was edited by: PhiberOptik on 2/25/06 11:41am ]</font>
What timing cover are you running? early model with mechanical pump or latemodel?
Are you sure that you have the right timing chain. You cant use a latemodel chain with an early timing cover, you'll have clearanc issues between the eccentric and timing cover similar to what you have going on there.
1 - 20 of 25 Posts
