Looking for the shifter hump, pedal assembly for a manual, or possible other parts. Really need to find the hump and something to use for the pedals first. I am rebuilding my late grandfathers and my first car a 1974 Gran Torino for my son. I'm in Pittsburgh, PA if anyone has any parts or ideas at this stage anything will help. Thanks!!
Just so you know they did not make standard shift torinos after 73 the 74 firewall is a little different so it will not be a straight bolt in on the pedal Assembly it will work but you have to do some modifications.
shifter hump is same for automatics and sticks
If you're still looking, I have a complete 4 spd setup out of a 72 gran torino, only thing is I'm currently in Afghanistan and won't be home till around thanksgiving. Let me know if you're interested.
I would most likely be intrested and time isn't much of an issue. PM me and we can work something out. Any idea what you would want for it?
I understand. Thanks. Most of this car is going to be a bit custom anyway. I love restorations and number matching cars but I love to drive them too much! Do you happen to know I the functional quarter window assembly from a 72-73 will fit?
i have most everything you need but the hump and trans.unless you want to install a richmond 5 speed with a long shifter on it.550 + shipping for pedal's and linkage's and bellhousing.900 on the 5 speed with shifter.
you can email me at [email protected] if you'd like pics
thanks john
if your still looking I have the hump and pedal assembly in a 72 GTS 4spd parts car I just picked up.it doesn't have the Z bar and linkage to the trans as the drivetrain was taken out prior to me buying.I have the bracket that bolts to the engine for the Z bar with the ball as it was in the trunk.
They had customized it with a hydraulic clutch master cylinder which is mounted to the firewall still and connected to the pedal but you would need a trans with hydraulic clutch to make all that work. if your interested PM me
