I have a 92 5.0 motor in a 74 bronco and need more fan to radiator clearance. Ford motorsport has a short water pump kit that includes a timeing cover and water pump. the pump is for a 94-95 mustang I know i would need new pullys but do I need to change the alternater and power steering brakets also? Is the 94-95 mustang timeing cover differant than the early 5.0? What other models used this short water pump and drive setup? explorer? T-bird? Thanks in advance
The 91-93 Tbird and Cougars used almost the same setup, except there water pump uses a threaded snout on them for the fan clutch to mount with instead of the normal 4 bolts. You can use there front covers and brackets, but the snout on there water pump is a pita.
