On 2006-05-22 16:20, mavman wrote:
5.4 is about 32" wide, 28" tall...and I have no idea how long.
5.8 windsor is about 24" wide 28" tall and again, no idea how long
The 5.4 is a HUGE engine!
just a littleLittle off on your guesstimate huh.![]()
What year 5.4DOHC in the Navi came with this 360hp...On 2006-05-22 21:26, rkite wrote:
Unless you get the DOHC 5.4 from a Navigator a 5.8/351 will make more power, and fit much easier, not to mention be lighter. The 5.4 DOHC was rated at 360 hp. The 5.4 3-Valve is rated at 300hp. I believe all of the truck 5.4 motors have an iron block DOHC and SOHC.
This motor may not fit with out cutting your car up. Then you will have to break new ground in electronics.
WOW. You have to do a progress thread on this one!On 2006-05-30 12:28, dave377 wrote:
Well guy I have a 05 4.6 3 valve engine and 5 speed trans out of a 05 mustang on the way so the fun will begine soon.This is going into my 64 fairlane with the ac. and power steiring and brakes going to be a job but will be well worth it when done I think.
