D05 is a soft compound (sticky), while the C07 is a medium compound (less wear) and a stiffer sidewall.
There is also a D06 which is supposed to be a combination of both--supposed to be a replacement for D05.
In order, D05 would "probably" be best for a stickshift, followed by D06 then C07.
Since you are in Arizona, there is no way I would stick a D05 tire on that car. While it is a soft compound, it doesn't work real well when the track temps get high. It's soft enough, it actually gets greasey instead of sticky.
