My dash keeps trying to slide off on the drivers side in my '71. Is there a missing bolt, or was it just glued in place? How do I fix?
sounds like you are missing a dash clip. They can be bought at dearborn classics. The clip , clips into the dash top, and then you slide the dash pad into the clip, and it holds the pad in place. hope this helps. Also a set of shop manuals might be helpful to you for this and any other problem you might encounter with your 71
