I have a 78 case fill C4, REV manual Tci vb.. edge pro convertor..
The trans is slow to respond when put in gear. Only when its first strated after sitting for a while though.
I can start it cold and it acts like theres no line pressure let it run a for a lil and its fine.. drive aroudn shifts are firm as allways no slip etc..
stop shut it off per say i go to the gas station fill up start it back up put it in gear its fine acts like normal.
Go to work park go to leave for lunch 4 hours later no line pressure?
Hard seals, sounds like to me. Change the fluid and filter, put a pint of Sea Foam trans treatment in it and see how it acts.
