Has anybody used the smallblock toploader behind a big-block.I know the input shaft is longer and I've heard it must be shortened or it will bottom out in the back of the crank.I know they will physically bolt together but I wonder if there would be a little bit of drag on the input shaft making it hard to shift.I'm not worried about strength and gear ratio's, just if it will work.
