I have a 351 Cleveland that had been sitting for around 10 years. I tore it down and it needs to be bored and have the crank turned. I want to use my stock 2V open chambered heads and then when i save up the money buy a set of aussies. It would probably get a cam, intake, and exhaust.
If i went with around a 9:1 compression ratio, how could i just bolt on the aussies and my compression would be in a range that i could make 400-450hp with the right cam and port work?
Could i use something like a 750 carb so i dont have to buy a new one as soon as i get my new heads?
With a pretty mild engine like this, does the rotating assembly have to be balanced?
What else would all have to be done to make that combo work. I know new valve springs, lifters with the new cam. I suppose i would need to get a new valve job. What does one of those cost?
One other option i have is this, i have a 302 that ran pretty well last summer, it has around 100K on it so i think it would be pretty tired. I was thinking of just putting a cam, intake, and exhaust, then just build the cleveland to my high powerlevels. My only worry is that the rings and such on the 302 would be so worn that even with the cam and other things it would still be quite tired.
I think i would be much happier with the mild cleveland then the mild 302, it would also be a better value for me to go with the 351 becasue i would have many of the parts i need, and then just add on as i get the money.
Any thoughts would be great, thanks for the help.
Edit: street 73 mustang coupe with T5
'71 Mustang Convertible,302, needs some work
Hopefully soon to come-'73 Coupe, 351C, T-5.
<font size=-1>[ This Message was edited by: sharpshot71 on 2/28/06 9:12am ]</font>
<font size=-1>[ This Message was edited by: sharpshot71 on 2/28/06 9:14am ]</font>
