This just recently started a couple weeks ago. Every once in a while when I go to start the car it makes an awful screech/grinding sound like when you try to turn the key with the motor running already. Its done this in cold and hot weather, dry and wet.. Usually if I let it sit a sec and try again it works fine.. others its 2, 3 sometimes 5 tries before it starts like normal.
does this sound like a bad starter? should I replace that and the flywheel as it could be grinding teeth??
