So I just reinstalled the 289 back into my 64 Falcon and while doing so I cleaned up some old hacked on wiring under the dash. This car had the ignition switch bypassed by the previous owner, and a simple toggle switch and starter button installed. It ran fine before I pulled the motor. This is whats happening: Car will run on start power only, I ran a jumper directly from batt pos to coil pos and while cranking I jot a little shock off the carb linkage. I mustve screwed something up under the dash. How can I basic wire this thing just so it will run? And where does the I and S terminals on the starter solenoid go to? Thanks alot.
Matt
Matt
