I'm running Autolite copper plugs, whatever the correct model # is for an Explorer with P heads. I tried Platinum but they fouled quickly with my old style ignition.
i have a built 351w thats built to a 363 stroker wanting to put a set of good heads on it its punched .40 0ver flat top pistons e303 cams highvolume oil pump 8 quart oil pan polished heads new valve springs and pushrods lifters ect. and forged crank im trying to get more power out of it and was told from the guy that built the engine if i went aluminum heads and diff lifters and rockers i could get it close to a 408 but im not sure what would be a good head to go with if any
Mustangbuilder - welcome to the Forums. But, your stroker question has nothing to do with GT-40P spark plugs. Please go to the Stroker Engines section and start a new thread. This will get you better answers quicker.
Go to the Stroker Engines section and click on New Thread:
If this is too far off topic, please ignor and I apologize ahead of time. If it is on topic, I'd appreciate the input.
I've been doing a lot of digging about putting EFI on my 66 Galaxie. Due to lack of resouces to do modifications required to completly convert to a late model modular, I'm...
just picked up a 351w that only has a few thousand miles on it but has been sitting around for a while. Tying to figure out exactally what this thiung came out of?
Block Casting: E4AE-6015-FA4 ..... date code 8C10
Heads (351w cast iron) ..... date codes 8C16
Intake D9DE-9425-CB .... aluminum...
Will the wiring connectors for the injectors on a 93 Mustang 5.0 fit Explorer injectors. Iam going to do the Explorer manifold swap or will the Mustang injectors fit the Explorer manifold?
Everything was fine with my el-cheepo 4 banger silver notch, until… on my commute home I smelled what seemed like burning electronics, this was just up my street, so I pulled into my driveway and quickly opened the hood, extinguisher at the ready. Couldn’t find a damn thing wrong. Was looking...
I am hooking up some BBK fuel rails on my 5.0 crate motor and am trying to keep fuel lines neat and orderly.
With the stock ford efi fuel rail hook up (86-93), the supply goes in at the front of the passenger side rail, goes to the pressure regulator(return), then goes thru the passenger side...
