i just got a speedo gear to correct my speedometer. i have never seen or know anyone who has swap one so could some please tell me how or a site i could go to to find out any info would be great help thanks
If you are just changeing speedo gears, it is real simple, whether auot or stick.
Jack the car up, use jack stands and wheel chocks, there will be a cable going into the tranny, could be right side or left side depending on tranny, and there will be a small 1/4" ( 7/16 wrench ) bolt going thru the cable holder, remove the bolt, pull gently on cable till it is out.
There will be a "C" clip going thru the little plastic gear, pull it out remove old gear install new gear, and put it all back together. lickity split. You have just changed your first speedo gear.
Don't you have to lubricate the new cable first? I haven't done mine yet because I thought you had to lubricate it. Well, that and I'm lazy.
