Reverse cut speedo gears.
Which side of the car does the cable go in, driver or passenger side?
Yep it has the wrong gear in it, turning the wrong way, it will take miles off your odometer though.Reverse cut speedo gears.
Yup knocked off 100 if those 107k.Yep it has the wrong gear in it, turning the wrong way, it will take miles off your odometer though.![]()
The driven gear has a slant to it. Look at the teeth close and find one that slants the opposite way.Changed from a 3 speed toploader, to a 4 speed toploader (with the input in the correct side) and the speedo is going backwards. This has me baffled. Any ideas?.
Probably a 3.00:1Does anyone know the rear-end ratio of a original 1964 Falcon 260cid three speed on the tree.
It's the right colour (yellow) and it's slanted the opposite way. Let you know in couple of weeksYaa it appears it's for a Mustang, I'm hoping the one in the original 3 speed will work. Any one know for sure?
Most are 3.25 to 1Probably a 3.00:1
