ok im driving at 40-45 and my speedometer drops to zero i check my cable and its disconnected....so i take the instrument panel off and that
cable doesnt wanna go back on...any tricks cuz im gettin pretty darn frusterated...thanks
Someone may have replaced the cable with one which was too short. Each end is supposed to extend about 1/16 inch beyond end of nipples for casing. If yours is "down in there" it is too short. Go to local speedo shop and have them cut you a longer one by appropriate amount. Doesn't take long to install once lubed, but I tend to cut wrists when coupling it up behind the instrument panel.
Wm.
