1 - 9 of 9 Posts
I have experienced for the first time today the joy of the Spirolox while assembling my Probe SRS slugs onto there rods & all I can say is - wow, bet you seasoned engine builders who use these spring steel muthas all the time have got finger tips made of leather!!
just make yourself a little tool for next time... works like a charm. get a small screwdriver(maybe 1/8 in wide blade) file a "step" about halfway across the blade.start the spirolock and then use the little step to wind the lock into place by pushing down and outward. easy as pie
Spirolox are one of the few things that I absolutely dread doing. Thankfully, once you get a couple of them in and figure it out, the other 30 aren't quite as bad. First time I did it, I spent about 2 hours on the first ring and probably took 45 minutes to put the other 31 in.
The Mahle pistons have round wire locks. Much easier.
Stretching them out a little makes it a much easier job.
Out sux, in just spread it a little sort of like a snake aroud the tip of your finger, and work it in with a small screwdriver
I got one better, try putting all the pistons on the rods backwards the first time even after I thought I checked and re-checked.
That sucked badly.
That sucked badly.
Ouch! Yeah I bet that DID suck!
1 - 9 of 9 Posts
