has any one had any good luck with them i had the spoertsman but not the pro s and they were only good for burnouts they didnt hook at all but i got a new set and im thinking of trying them .
I have seen many cars use them at the drags. They don't work too bad, but they aren't designed for drag racing as much as they're designed for street-rodding and such. Most make the mistake of backing into the water and doing a huge burnout which makes it worse...the treads hold the water and the huge burnout makes 'em greasy.
Discussion Starter #4
these came on my 65 mustang im thinking of putting them on my falcon there 29x18.5x15 if i can get 1.70 60 foots ill be happy .
They are similar to drag radials but they have 2 ply nylon wrinkle bias walls and a softer compound. Run about 16 psi in them and pull around the water box and back in if possible. Do your burnouts from the wet edge of the water box and give em a good smokem-up!! You'll be surprised at how good they grip when they get heated up right.
