Was recently working on my Ignition problem on my 87 Crown Vic with a 5.0 lt FI. Found out the problem was with the ignition module and I have replaced it. Along with the coil, pickup, wires cap and rotor. It need all of them, it has 86000 kms. My Problem is now after timing it to about 9 BTDC I have a miss but only when the SPOUT Connector is plugged in. I had to remove the connector to time it but as soon as I put it back in, it missed. I am drive it now without the Spout in and it seems to run just great. My question is: Am I doing harm to the ignition or ECU without the Spout connect and can I still run without it. The milage even seems a little better. THANKS>>
