can a bad headlight switch cause my torino to stall out.....i took apart the dash the other day because my car would stall out evry time i would turn the headligts on or step on the brakes or put it in reverse n it had been sittin for awhile so some friends said maybe rats got to the wires n go figure they did to the wires running to the rear lights n i patched those wires up n it solved the problem to that end for when i would brake or put it in reverse it would do the same n not no more but the as for the front its still does it and iv checked the wiring n its good n im thinkin its the switch but not sure do u guys have any suggestions it would help im tryin to get her bak on the road
