Car: 1967 mustang coupe, 289 automatic.
History: We are doing a complete cleanup and replacement restoration. The engine has been completely rebuilt, the undercarage was stripped, cleaned and painted and all moving parts repaired or replaced. Trans was cleaned and fluid/filter changed.
Engine: complete block cleanup and machine, bored .030" crank .010" and 010" thurst bearing, complete head rebuild and new valve springs to go with new the mild cam. Flat top pistons, with moly rings. everything else was new inside and reman hang-ons along with the polished intake and edelbrock 600 carb, headers, and chrome accessories. Everything was installed by the book as they say. So ...
Problem: Engine starts and runs good (nice and loud), but will barely restart before it gets totally to operating temp and won't start once the thermostat opens. Seems like the battery goes into strain mode, battery cables get hot fast. I checked timing and its at about 8-10° BTDC. The battery is a new basic 425 cca issue for this car and probally could use a stronger one. Again, everything was replaced except the coil and distributor but has new points, condenser, cap, rotor, and wires. Going to HEI later when funds permit. The engine will restart after cool down of about 3 hours. Anyone have any ideas?
Thanks ...
Thanks ...
