Hi,
Can someone tell me if i am checkin my solenoid correctly?
I ask because I didn't hear the famous "click/doink" sound when i turned my key to "start".
When key is in the "on" position the "I" terminal reads 12V, the "S" reads 0V.
When the key is turned to "start" both "I" & "S" show 12V. BUT the terminal that connects to starter reads 153 mv or volts or something weird.
Also the positive side of coil reads .53 volts when key is on "on" position.??????
This 408w build is finally ready to start. I will actually install starter when i figure out this solenoid issue.
I appreciate you input!
