1979-up 460's are externally balanced from the factory; 1968-1978 engines are internally balanced.
The internally balanced engine has a crank spacer right behind the harmonic balancer that is nothing more than a sleeve, really; the externally balanced crank's spacer has a "hatchet weight" incorporated onto this sleeve/spacer.
The edge of a crank counterwieght that is stamped "2Y," "2YA," "2YAB," or "2YABC" is an internally balanced crank, while a crank that is stamped, "3Y," "3YA" is externally balanced. (Or possibly no markings is usually externally balanced
<font size=-1>[ This Message was edited by: 64TBOLT2 on 5/18/06 2:09am ]</font>
