I'm dropping a '94 351W from a Ford truck into a '67 Fairlane and wondering if there's any reason the stock distributor won't work. Does it get wired like an original points style distributor?
Alternatively, I'm considering a Petronix distributor. Should I just forget about the stock unit?
the 94 351w should be a roller cam isn't it? If so you need the distributor with the matching gear (bronze?) or you'll ruin the cam or the dizzy
Will NOT work. The 1994 truck likely has a hydraulic roller cam. If so, it uses a melonized steel gear. The cast iron gear from your 1967 will not work. Plus, the 351W was not out in 1967... and a 302 distributor will not work in a 351W.
If you use an iron gear on steel hydraulic roller cam, the metals will not be compatible, and will eat each other.
Mike is correct (if it is indeed a roller cam.-------You will need to check and verify as not all are rollers.)
In addition the oil pump drive on a 351w is of a larger diameter (than the 289/302) and it will not fit into the distributor shaft (whether roller cam or not.)
