So can a stock 351w (.030 over) that hasn't been run yet have it's rotating assembly swapped out for a 408 one with just basic tools, torque wrench, dremel, and a micrometer? I have never really dove into a bottom end before but don't feel like spending another $1k at the machine shop since the honing and such has already been done. thmx
Yes, you will have to assemble to check for clearence. Then have it balanced.
Should be just minor clearence work.
a 408 kit will be the way to go.
Can the assy. come prebalaned like from cnc-motor. so then it will be just assemble and clearances?
Yes you can get them balanced, just watch out for the parts that are used, some great, some good, some are just plain junk.
I second Woody's comments on non-branded parts...
I sell the Scat or Probe kits - - in main part because its all brand name stuff I can trust. The mystery metal in some kits gets me nervous...the inside of your motor is a crummy place to try and save $50...buy cheaper valve covers or go without floor mats or something...
And yes - we can all get kits ready balanced either to nuetral or 28 oz. You beed to clearance the bottoms of the bores and such - but your machine work will be OK as long as you have a steady hand... Most decent kits will be floating pins and fairly easy to assemble - - I recommend one trip to the machinist to check piston to bore clearances and pin fit - not at all expensive but well worth doing. Most of the time things are OK - - but this is the time to check...
Heads are off for because I just did some more porting work and the block is sitting on an engine stand waiting for me to do something.
Theres a thought. thanks.
<font size=-1>[ This Message was edited by: dugedug on 11/29/06 1:04pm ]</font>
I have always heard that it is a good Idea to have the rotating assembly balanced with the dampner and flywheel/flexplate. therefore I would have it done at a local machine shop 150 to 200. other than that its pretty much DIY
