I just pulled the six out of my 68 and I'm building a 86 302 to replace it. I've already replaced the rear axle with a 8" unit and upgraded the front to disc brakes. I'm trying to collect everything I need so I can keep the process as painless as possible. I know I will need to get engine frame mounts, radiator, timing cover and replace the throttle linkage with a cable system. The car is a C4 auto column shift. I plan to replace the C4 with a rebuilt one but not sure if linkage/trans crossmember will need to change. Am I forgetting anything? Will mustang oil pan, motor mounts, etc work? Advice on where I can get throttle linkage?
