I have a 1974 C4 transmission that has a strange problem. All forward gears work just fine. But the reverse acts very strange. If I pull into the garage, turn off the engine, then place the shifter into park, the next time I reverse out of the garage, no matter how long of time it is, it backs out in reverse no problem.
However, if I pull into the garage and put the shifter in park, then shut off the engine, the next time I back out of the garage, no matter how long of time, reverse binds up and I have to give it full throttle to get it to move in reverse. It just started doing this one day.
It is binding up like it is in drive and reverse at the same time. I have pulled the transmission, completely disassembled it and can't find anything wrong. Re assembled it and same problem. Installed a different known to be good valve body, same problem.
I have rebuilt many C4s before and never had a problem like this before. Has anyone else had a similar problem or just me?
