The point is that the person who asked the question doesn’t have to choose one over the other. I am suggesting taking better cylinder head flow while maintaining your compression. It would be foolish to take over a one point compression loss (difference between a 54cc combustion chamber and a 64cc one on a 289) when you don’t have to. The difference between 8:1 and just under 9.5:1 compression will be pretty noticeable.
This is what I did but used much bigger and higher flowing parts than what you suggest. 10:1 true compression, old style 950 Holley HP based carburetor, Parker Funnel Web intake, Canfield 195 heads with 2.02 intake valves, .650’ish lift 224 at .050 lift duration intake lobe cam, full length headers into 3” dual exhaust. Stock 1965 289 block bored .060 over, stock 289 crank, 289 rods with ARP bolts and probe forged pistons.
Lowest we pulled it on the engine dyno was 2,800 rpm where it was already making 274 lbs/ft. Made 400 hp by 6,000 rpm and a peak of 430 hp by 6,900 rpm. Street/strip toy. Not what I would recommend for a daily driver nor would I recommend this for the the thread starters needs. Just an example of can be done when you keep compression a priority
Taking it out for a cruise on the street. At about two minutes 10 seconds into the video I do a half throttle stab in first gear and then one in second gear from a roll. Low end torque was not an issue.
