My lifters won't compress. They are Comp Cam's. When I bring the nut of the rocker arm just until it touches the pushrod and try and tighten 1/2 turn then my valve starts to open. I'm on TDC, verified by the distributer and removed spark plug. I have let it sit for a few days same problem. I can start the motor with all of them adjusted to where I just touch the pushrod but it is very noisy, clatter. Should I take an old pushrod and tap it with a hammer and try and loosen up the lifter? Help! This is driving me crazy. Brand new motor
tighten each one tell there is no noise, then double check them, loosen them one at a time till they make noise then tighten till the noise goes away. After you have them at 0 shut it down and turn them all 1/2 turn.
works for me
what cam do you have
I just verified the the valve closes after about 30 seconds with a dial indicator. I jumped the gun. What I'm having problems with is clatter. I will go back and set each cylinder at TDC and turn them 1/2. I have Edelbrock heads with guide plates and Trick Flow pushrods. Will the guide plates cause noise? I've been out of this game for awhile and noises from a new engine scare me. Oh, the cam is what Jasper Engines call a stage 2. I bought a short block from them.
What cam are you using.It's not unusual for some of the cams now with high intensity or fast lobes to have a little valvetrain noise.
