Putting the 302 together tonight and sheared a screwdriver tip trying to move a rod journal over the make room for the last piston to go in. I said to my 16 year old son, "well, this is #8 piston and so far so good. Lets button this bad boy up.".
So, in dropping her in, the rod hung up on #4 so i tryed moving it over BY PRYING IT OVER WITH A SCREWDRIVER! STUPID!!!! Well, to make the stupidity worse, knowing a small tip of the screwdriver was missing, i proceeded with putting the cap on hand tight. We found a small piece of it on the ground and assumed that was all of it. Then went to turn the engine over to check the rotation and it wouldnt budge. I knew right that second what was up. Took #8 back out to find a small piece between the bearing and the crank. Yeehaw. Good times. Live and learn i suppose.
